V5 Analysis Primer or Tutorial
kyeohti
9
Does anyone know of a good CATIA V5 Analysis primer documentation or tutorial? I need to use the Generative Structual Analysis workbench to calculate the deflection under strain of my assembly.
Thanks,
Michael
Hi kyeohti,
You should consult the help for the information needed.
Off-topic:
[li]I wouldn't recommend CATIA for FEA analysis, especially not for an assemblies. Check out ANSYS, Abaqus...[/li]
[li]If you really need to do that FEA analysis, do it for a single part; the chances of huge errors appearing will be lower.[/li]
Hope this link helps.
Best of luck!
I recommend this book:
"Catia V5 FEA Tutorials", by Nader G. Zamani
