V8 LS1 flywheel racing weight 4
sierra4000
Automotive
Oct 17, 2013
239
exist recommendation for minimum flywheel weight?
how way is harmony ballancer improtant?
we build racing engine and try minimize engine inertia
thank for all comments,
Radek
Radius of gyration gets you to the average velocity of all molecules in the rotating flywheel, basically, as if they were traveling in a straight line instead of rotating, so you can make direct comparison to the rest of the car which is traveling in a straight line.
Consider a 10kg flywheel in a 1500kg car... From GG's example in first gear, the flywheel represents (10*25)/1500 = approximately 17% of the inertia the engine is accelerating.
Looking up radius of gyration on Wiki can clarify what it means to help with the understanding. It's a great way to do a simplified explanation comparing flywheel to car weight. Why'd you post that flywheel mass makes little difference? It certainly does, especially in the lower gears.
