Hi everyone,
I am trying to calculate the CV for a back pressure valve (BPV). I have a BPV holding the pressure in a vessel to 50 psig, i.e the BPV is set at 50 psig. How do I calculate the CV for the valve? CV is dependent on the inlet pressure and pressure drop. However, since we have a BPV, the inlet pressure to the valve will always be 50 psig unless the valve fails. Even if the pressure in the vessel builds up, the BPV adjusts it's orifice opening to get the pressure back down to 50 pounds. Hence, the inlet and outlet pressure ideally should be around 50 pounds (give or take a few).
So, what pressure and pressure drop values do I use to calculate the CV? If BPV works as it is supposed to, then pressure drop should be 0.
Also, what will be the maximum inlet pressure possible? If I understand correctly, the inlet pressure will always be around 50 pounds (unless there is a failure).
I will really appreciate any assistance that I can get from our more experienced colleagues on this site.
Thank you all.
Berenger.
Thank you all.
Berenger.
