Valve Identification - schematic symbol 1
Can't see the picture because it's not embedded in post. And I refuse to download attachments and repost them any more. There is a "Camera icon and it says "Image" next to it. Please use that "fancy" feature...
I originally tried to use that but i asks you to select a file. I select a file, then the only button i have left is cancel!
How about if I describe it to you.
Picture a proportional valve 4 port 2 position (infinite position, spring return, electrically actuated)
Normally closed position = all 4 ports are blocked with a "T" in each position
Open position = shows two arrows one pointing in one direction (straight up) and the other pointing the opposite way, (straight down)
In addition to the arrows there are flow restriction symbols ")(" that straddle each of the two arrows.
I think I have identified this as a proportional throttle valve with chokes inline with the flow paths.
The question i have is this. Since the arrows only point in one direction does this make this flow only one way? Or is it possible to reverse the flow through that valve?
This is basically being used as a buffer system for an oscillatory device so there is no pump or tank.
Jon
The arrows pointing in opposite directions are part of the standard symbol - just making it easier to understand what's going on when you look at a three-position valve.
We use plenty of them with flow ignoring the arrows.
A.
When you've selected your file click the Open button on explorer and it zaps the photo into the post.
Thanks Zeusfaber!
I figured as much but before i opened my mouth i thought i would ask the experts.
@ LittleInch, I did try what you mentioned originally, but when I click the open, nothing happens, no zapping and the upload image dialog still remains (with no file selected) The file is a .jpg so its not the wrong filetype. Maybe its my browser.
Thanks guys!
Jon
Hello
Note that the arrow along the line indicates a press compensated proportional valve. That would mean at each setting it will maintain 'about" the same flow regradless of delta P. Note that putting a manual flow control downstream (say for stabalizing back pressure) of a press compensated valve does not do much good. The press compensated valve will dominate the flow.
this may help you:
if too small, please see my attachment.
R.Efendy
