jean genibrel said:
I would like to know if anyone out there knows how to plumb a valve spring oil cooler.
Are they gravity activated, do they need a pump like for gearboxes and diffs?
After following your link, the answer becomes clear. Note that the series of Setrab coolers you have linked to are noted for use as 'Valve Spring' AND/OR 'Power Steering' coolers.
Of all possible cooling loads you could create in an engine system by plumbing a separate cooling loop, valve spring cooling and power steering cooling are going to typically be by far the smallest cooling loads. Meaning they would require very small heat exchangers compared to, say, a transmission cooler.
If you wanted to cool valve spring cooling oil separately from everything else, there is only one way that I can see it being possible; you'd have to have a separate dry sump pumping stage for the valve spring oiler supply, plumbed with the (tiny) heat exchanger in line between the pumping stage and the supply on the cylinder head(s).
You can't separate the valve spring cooling oil from the rest of the stream, because once you spray it inside the valve cover, it's getting mixed with other sources (ie lubrication for flat tappet lifters or whatever else is in there) as it drains back to the sump. So cooling prior to spray is your only option.
This is why the other guys are talking about dry sump pumps - because having a dry sump pump with a dedicated stage is the only way to provide cooled oil to the valve spring oilers and the valve spring oilers only.
With all that said, even in the most demanding applications, I can't imagine the flow required to properly supply valve spring oilers for cooling is so gargantuan that you would dedicate an entire dry sump stage to it. Maybe I'm wrong about that, but I don't see it. If I were building an engine and felt that spring oilers were necessary, I'd probably source that oil from a dry sump stage that is already supplying oil to other relatively low volume destinations - like piston skirt oilers, cam bearings, whatever.
In short, I'm pretty sure Setrab calls these 'valve spring/power steering coolers' because the heat exchangers in that particular series are so small, that those little cooling loads are all people ever use them for. But the coolers themselves aren't 'special' in any way.. they are just a smaller version of the standard Setrab cooler you'd use to cool a transmission or a rear end or whatever. That fact is obvious from reading the catalog. They're like normal Setrab heat exchangers, just tiny.
