enginesrus
- Aug 30, 2003
- 1,013
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
That's very much the idea with VVT Miller cycle optimized engines. They do leave a little power density on the table vs engines that are optimized for high voleff at full load, other constraints such as emissions notwithstanding.TugboatEng said:Variable valve timing can also be used to control compression ratio while still maintaining a tight squish clearance and high expansion ratio.
