Hello, as a final school project i would like to design a system that uses both constant variable valve timing along with constantly variable intake. This would be for a race engine setup. Basically telescoping intake runners, that are synced to the cam variation as well. Change in both is based on engine load and throttle position.
1) is factoring engine load necessery for this to work effectively, or is throttle position enough?
2) What kind of setup would be best for the motorization of the telescoping intact tracts?
3) Im thinking electro magnetic magnets for the VVT system, (unless the project scope allows me to use a current manufactureres VVT system, and then i just integrate the variable intake..)
