VBA Macro : Check if the windows is a DMU Navigator 1
nekcorp
New member
FR
I would like to know if the active window is a DMU Navigator or not. Can you help me ?
Below the code I use. When I launch it I have the error message at the line TypeOf activeWin Is NavigatorWindow:
Compilation Error:
Type defined by the user is undefined
Code:
Sub VerifierDMUNavigator()
    Dim activeWin As Object
    Set activeWin = CATIA.ActiveWindow
    ' Check if the active window is an instance of NavigatorWindow
    If TypeOf activeWin Is NavigatorWindow Then
        MsgBox "You are in DMU Navigator"
    Else
        MsgBox "You are not in DMU Navigator."
    End If
End Sub
Thanks for your help
@ferdo
Thank you it is works [2thumbsup]
