VC++ vs VB vc C#
Jevakil
41
I am a mechanical engineer, turned programmer. I have some experience with VC++ and VB. While I like the simplicity of VB, I don't like its lack of strcture. VC++ on the other hand is well organized and very powerful, but when it comes to COM it is a nightmare (at lease for me). Does anyone have experience with C#. How does it stack up against the other 2 languages. Specifically how easy it is to develop windows programs and use or create COM interfaces?
C# is much closer to Java systactically than it is to C++. C# has some elements derived from Visual Basic and Java but C++ is C#'s closest relative.
(I do'nt consider Visual Basic as real language).
1. c++ is unmanaged c# is managed (type safe).
2. c++ performance is twice c# in program load time ,
Integer calculations and database access since c# works
in .NET enviornment.
3. It is suggested that in .NET programmers can get more
done in less time than before.
C++ is arguably the most powerful language ever invented. It has always been a systems language, and it gives you the power and flexibility to produce truly flexible and innovative solutions.VC++ is the only language where you can mix managed (.NET) code and unmanaged code in the same assembly, and even in the same source file.
Also Java is a general purpose, concurrent, class-based, object-oriented language and I would pick it over c#.
I know you don't consider VB a "real" language, however, it does have it's advantages. It is in use by many companies for several reasons. In the dot net environment, VB.Net runs on the same engine as C# so the differences are in the development. Everything I have seen about development in Dot Net indicates productivity is better.
I definitely did'nt mean that VB does not have any usage. I
meant that VB is good for application programming, like
database applications with forms and so on.
For example if you wanted to develope a RealTime control
system for a chemical factory, device drivers , compilers, etc. and basically Systems Programming, c++ would be the answer.
Thanks...
