Rookie question here: I am trying to verify the size of some chilled water piping in a mechanical that was originally remodeled in 1973 (drawn, documented and specifications still available) and modified in the decades since. I am struggling to figure out what a particular size of piping is, especially since several as-builts from different conflict with one another without any indication that any pipe was replaced. I am aware that getting a pocket knife to cut through the insulation to determine its depth is a very bad idea, as the seal preventing condensation would be penetrated, but I am at a loss as how to determine on the field the best way to measure the pipe diameter. Does anyone have an idea of any tools or tricks I can try to use to figure this out? Thank you in advance.
