struclearner
The load on the wheel rim from the weight of the vehicle is assumed having a sinusoidal distribution with an angle of distribution.
The sum of total distributed load will equal to the total force acting on the wheel.
Is the cosine distribution of the load have a vertical component only or it will also have a horizontal component acting on the rim as the load point of application moves away from the center location where the load has only vertical component.
If I need to determine the load to apply for fea, how the sinusoidal distribution of the force can be calculated for an angle increment.
Thank you very much for your help/referring to the link/material dealing with the subject.
