GaTechTheron
A quick question:
-Assuming a constant speed vertical turbine in an open pit without a strainer: Does Submergence vary with pump flow?
-With a strainer, can you assume that no fluid level is required to avoid vorticity? Or rather, does a strainer surpress vorticity 100%?
Thanks!
Thanks!
