strainstress
- May 15, 2011
- 63
I am trying to figure out what supports to use to mount the vessel. The vessel has a 54" diameter and thickness of 5/16" (See attached rough sketch). The vessel is to to be mounted to customer beam platform at 68-1/2" spacing using 4 mounting legs.
The legs are made of 3x3x1/4" tube welded to the vessel. The requirement is that the vessel cannot dislodge during a seismic event and has to maintain its structural integrity. If the tube and weld size are adequate, what modes of failure in the vessel at the tube-vessel connection should I check ? Since the requirement is that the vessel cannot dislodge, is just checking for tube punching through the vessel wall adequate . How does the local bending stresses developed at the tube-vessel connection effects the strength of the joint ?
