Vestibule Drop Ceiling Wind Load Classification
A. Harcher
1
Hello all,
I am having an issue finding the proper wind load classification for a drop ceiling I am designing in a hotel vestibule. I have read through the Structural Wind Load section of the 2012 IBC, could this fall under a components and cladding classification? I'm a new engineer so this wind load classification has me stumped and looking for some help from experienced minds. Thanks.
- A. Harcher
Maybe it's different for other parts of the US/world, but I understand a vestibule to be the 'airlock chamber' of the building - the small room used as an entryway before entering the lobby of a building.
If that's the case, then it's an interior space and not subject to wind loads. Am I understanding this correctly? Could you perhaps be referring to a canopy - an exterior space before entering the vestibule or doors of a building? Open roofs would then be what you are looking for.
If it is interior, it won't see wind loads. For an interior soffit, I don't think the 5 psf interior lateral pressure applies, either.
DaveAtkins
I would be inclined to say in a vestibule the interior 5psf would apply. When it's a super windy day and someone opens the outside door (with the inside door still closed) the interior pressure would skyrocket.
Should be the same as for the vertical surfaces abutting the ceiling. Pressure is in all directions.
Why isn’t this akin to a partially open building or space, with the potential for some fairly high pressures, generally pushing upward or outward?
Agree with jayrod and hokie66...for the same reasons!
