Kiwinjuneer,
Nice questions. As one who has witnessed this industry for over 30 years, a mfr of the Meta-Lax line of eq, and a planer-mill machine shop owner, I can answer your first 2 q's (and I don't know the third). But before I do let me point out that "vibration" is much like heat - there are lots of diffrent energy levels. Like heat, there is an optimum zone that will produce successful results. Also, like heat there is an energy zone that will adversely affect your parts including causing fatigue. What we have found from our own experiences in our machine shop is that SUB-harmonic energy is optimum when using vibratory stress relief. We call this process META-LAX. This was also mathematically verified by a PE from Lockheed. Successful results from using sub-harmonic vibrations will be CONSISTENT machine stability, reducing "premature" fatigue, and reducing delayed distortion. Now for the answers.
1. Clarify fatigue life improvement. By applying sub-harmonic vibrations "premature" fatigue can be reduced. The fatigue life of sub-harmonic treated parts will be extended compared to non-treated parts simply because sub-harmonic treated parts tend to last up to their designed strength whereas non-treated parts tend ot break well before. An example of this is from Corrosion Engineering who makes vibration screen decks for the brutal mining industry. They reported in an article that after using sub-harmonic vibrations on a very critical part of the screen deck called cross-tubes that they eliminated cracking from use in all 600 cross-tubes they mfrd strecthing over a 4-year period.
2. Reducing stress buildup by periodic SR. YES, here is an example. The aluminium die cast industry tears up its tooling routinely around 125,000 shots. Yet if sub-harmonic vibrations are used periodically (we suggest at 20,000 shot intervals) die casters report sometimes up to a 4-fold improvement. Similar examples can be found from high performance racing.
Caution, beware of putting any value on reports that were conducted by students which contain no hands-on application for proving their thesis, like the CEER report.
There are well over 140 application photos on
website, many of those indicating longer service life from treated components.
What is your application?
BTIGuy
