Is there a section of any ASME specification that talks about how views on multi sheet drawings should be labeled? I am not referring to cross referencing for things like sections or details, but on complicated drawings where the views may be repeated on subsequent sheets with different features dimensioned. (For example, a machined electronic enclosure where sheet 1 may have the box dimensions, and sheet 2 may contain similar views but dimension the holes). Does there need to be some sort of cross reference to the views? Maybe one view labeled "top" on all sheets, or some other relating verbiage?
Thank you,
Thank you,
