view sectioning in 3D part / assembly
dkakth
46
Dear colleagues,
Do you know if it is possible in CATIA to create a sectioning view in 3d modelling part / assembly environment, which is not "plane - based" ?
In other words: is it possible to create a section view with a sphere or a given surface or volume as a sectioning tool ?
thanks in advance and kind regards !
You can temporarily SPLIT a part with a surface to see it's section.
You could also temporally SPLIT all the parts in an assembly.
The sectioning tools are planar only.
