Viewing files on other computers.
ryandias
Automotive
Jul 28, 2006
197
I have to make my model mobil.
In Inventor i know they have a Pack and Go function that searches for all the nessesary files for an assembly or draft and exports them to a zip file.
Now does SE have a similar function? or do i have to manually copy the files that are used?
you can copy all referenced files by using Revision Manager (Insight Connect).
Start Insight Connect -> File -> Open -> Revision Manager
cheers
Michael
Are the files for working or viewing only ?
Insight connect allows view and markup and will create a '.pcf' file.
This is a reduced file containing your assembly and al the referenced documents which can be viewed by anyone with the solid edge viewer. SE itself is not required.
Otherwise use Rev Manager to copy the files to the required location, as VBSpawn says.
bc
