Viewing sketch on the drawing.
polaris7eng
36
Hello
I am doing drawing and when I am switching between sheets there always some small problems with visualization of sketch.
I suppose this is well known detail about settings but "reviewing" doesn't help. After de-activation of sketch everything is ok but this low quality of the view comes again after each switching between sheets.
Look at the attachment.
Hello
Is there anyone who has a suspicion, which is the reason for the problems with the displaing. I suspected it was something more obvious. hmmm..
It's not clear what your complaint is really about...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Move Sketch into a Layer.
Nx 7.5.5.4
Teamcenter 8
Hello.
I did new drawing and now is better (moved sketch to layer).
My problem was about some error and misunderstanding how NX works.
At the beginning I see that everything is ok and when I am adding sketch and ZOOMING IN then the problem appears. The very rough view appears when I am zooming in. ("editing sketch" don't make complication that I suspect at the beginning)
Now I am using: View>Operation>Regenerate Work, and the view is regenerated properly.
Thank you.
