ViewPortLayer ; am I dumber than usual?
MikeHalloran
14,450
Using V1R5, Fedora version, under CentOS 6.5, latest.
No issues of any kind were reported at installation.
I've produced a simple 2D model in model space, and went to paperspace tab1 to produce a drawing of one of the parts. ... for which purpose only two of half a dozen layers need be visible.
In two hours of beating on VIEWPORTLAYER, I've managed to freeze exactly one layer in that tab.
How am I holding my tongue wrong?
Mike Halloran
Pembroke Pines, FL, USA
Hi Mike,
Maybe I'm not completely understanding this, but did you try the freezing the layers using the drop down menu of the layers toolbar? I know that that freezes the layer in both mspace and pspace, but for the purposes of printing a drawing it may work.
Best,
Medeski
No; I'll do that as a last resort, of course.
What I want is to freeze most layers in each viewport, so that I can generate in paper space in each tab a drawing of just one of the multiple parts represented in model space on a different layer per part. ... exactly like VPLAYER does in AutoCAD.
Part of the problem may be that the mouse response is severely delayed on my old laptop. I could swear the prior release, or the one prior to that, was much less aggravating in that respect.
Mike Halloran
Hi Mike,
I was able to get it to work for me. I copy pasted the command prompt. The first 3 lines were automatically generated when I double clicked inside the viewport to get from pspace to mspace. Does it still seem like a lag issue?
: _ACTIVATEVIEWPORT
Default: 4
Specify viewport number to activate» 4
: viewportlayer
Options: ? to list, LColor, LStyle, LWeight, Frozen, frozen from New, Reset, Thaw or Visibility default
Specify option» F
Default: Specify entities
Specify layer name(s)» HIDDEN
Default: Current
Options: All, Select or Current
Specify option» C
Yeah, I get prompts like that, but it doesn't seem to recognize the layer names most of the time, whether specified singly, with commas, or by wildcard (layer_name*).
Also, the cursor in the graphics field lags the computer's cursor by a couple of seconds, and it seems to have a predilection for a 'box select' instead of a single click to select what's in the target box.
Mike Halloran
