hk5528
Computer
- Aug 1, 2023
- 2
I have a setup of 1.5KW 220v pure sine inverter with 3Kw peak, and 400Ah lifepo battery, which I have tested with heat gun and run for 20-30 mins at 1.4-1.5KW w/o any issue. while I have just tried to run mobil air cooler 220v 12000btu with max power consumption is around 1.2KW I have encountered an issue. When I used with grid have no issue and max power consumption that I have seen on the meter is around 1.2KW for a/c.
Problem is happening with inverter. When the a/c compressor starts voltage drops to 150v which causes even more amp consumption. What I have thought is to if I can apply a soft starter SSR to solve this problem, may be something similar to, because I m not sure if I upgrade the inverter to 2 or 3kw pure sine would solve the problem or not? thanks in advance for reading and advices.
