Voltage limitation on Underground Cables at Mine Sites?
majesus
262
Pennsylvania Bureau of Deep Mine Safety has a voltage restriction on underground transmission at mines:
"Secondary or underground transmission voltage shall not exceed fifteen thousand volts, nominal, phase-to-phase. "
Does anyone know if the larger national governing bodies such as OSHA, MSHA, NEC and even CSA has a voltage limitation for transmitting power via underground cables at mines?
I did look through
CSA M421-00 Use of Electricity in Mines,
CSA C22 No 96.1-04 Mine power feeder cables
and OSHA and MSHA websites.
Didn't find anything particular on this subject underground transmission cables.
I too am unaware of any such regulation. I did as you did majesus and looked through my copy of CSA M421-00 Use of Electricity in Mines - I found nothing.
I understand that there are many coal mines in that region - in that regard a limitation on voltage seems to make sense. It seems to me that fifteen thousand volts, however, would be more than sufficient to ignite stray coal dust.
I did find the following document on the MSHA website, but it only very briefly discusses the amount of electricity needed for coal dust ignition.
Cory Anderson
