abusementpark
Ok guys,
If you are designing a wall stud as a beam-column and you have a two layers of wood sheathing on each side, is the stud braced for both compression and bending?
What about if you have wood sheathing on one side and gypsum on another? What about gypsum on both sides?
Intuitively, I think we can all see that these studs would not be completely unbraced and the sheathing would offer some resistance to buckling, but it might be hasty assume full bracing. Is there a legal document or code that quantifies this?
