Denob
- Feb 11, 2005
- 28
I am currently working on a large diameter water transmission line project where PVC, ductile iron, steel, and bar-wrapped steel cylinder concrete pipe will be incuded in the bid sheet and specifications. The idea is to drive down prices due to competetion. My question is: What material do I design for? Should I design for the material that I think will be chosen (lowest bidder)? Do I design for the most conservative material overall? Do I design for the most conservative material for each facet of design (which could mean designing for PVC for joint restraints, designing for steel for pipe deflection, etc.)?
