inovermyhead
Agricultural
- May 1, 2009
- 9
Does anyone know the formula for calculating the distance a windmill will pump horizontally?
An 8ft windmill will lift water 180ft with a 1 7/8 cylinder pump. If my static water level is 60ft and the cylinder is @75FT I'm pumping up to the surface 60 ft. I would like to know how far I can pump after that point horizontally. Surely water will move easier horizontally than vertically.
other factors that may influence distance......
1 1/2" pvc pipe at the surface only
drop pipe is 1 1/2" galvanized
I'm at 220 ft above sea level
flow of water is not constant in the pipe
thank you
thank you
