Weight measurement on CAD using area density
Jeremias08
Automotive
Mar 11, 2015
1
Does anyone knows how to measure wegith using area density on NX for non regular bodies?
You will increase the likelihood of getting an answer to this if you post your query in the Siemens: UG/NX forum at:
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
whilst i don't understand "area density" ...
one way (very olde school) would be to apply a body force (say 1g down) and the reaction would equal the weight;
another (an artfull combination of new and old) would be to 3D print your part, immerse it in water, to determine it's volumne ...;
another would be to ask the cad program that created the part "what's the volume?" and take it from there.
The way that I typically find the mass of a design in NX is to do the following:
While in the Modelling application, Go to Analysis \ Measure Bodies select the components of interest, then in the drop-down menu select volume.
Once the total volume has been determined, simply calculate mass by using the materials density (I usually check matweb.com to find what I'm looking for).
-MJ
