Ray2020
- Sep 14, 2019
- 10
When working on a simple beam model the forces extracted from joints in that model show forces correlating to an acceptable weld capacity.
When the same structure is modelled with finite elements (plate/shell elemets), sometimes you might see that for this same joint a significant portion of the length displays forces correlating to a non acceptable weld capacity. This is because FEA can provide better resolution. If the average force per unit length of the entire length was taken then this value will correlate to an acceptable weld capacity.
What do you do in these circumstances? Do you just take the average along the entire length?
Not everyone performs FEA on structures, if someone is using a simple beam model in combination with standard AS 4100 to perform their calculations then they wouldn't notice this problem.
Or do you just keep assuming a thicker weld until results correlate to a passing capacity?
