BigBakwas77
I provided a normal HSS102x102x6.4 lightly loaded column (axial 50kN, shear 2kN) with a 20 thk base plate and 4-20Ø A325 anchor bolts with Hilti HIT HY200 on a project where the base building is existing. Now the architect has come back to tell me that he cannot accept the base plate and bolts/nuts exposed above the concrete surface. I am proposing as per the attached sketch. My questions are,
1. Is it acceptable to remove nuts and plug weld the hole 10mm (half the plate thickness)?
2. What type of bolts will be weldable? ( I have seen F1554 grade 36 as weldable.)
3. To what extent the welding (heat) affect the Hilti connection to concrete?
4. Would mechanical fasteners be better solution than chemical ones?
