bonkers
- May 13, 2008
- 28
Can someone refer me to the welders qualification code. I am researching if welding to a vertical pressure vessel support leg requires special qualification, procedure and inspection if the portion of the leg is not contacting or within some predetermined length from the pressure components. Are the legs considered part of the pressure welding code zone? Can you weld to legs without an alteration or rerating?
Thanks,
Bonkers
Thanks,
Bonkers
