welding simulation with SYSWELD 2021
Ace-737
Industrial
Dec 27, 2023
3
thread727-50044
[highlight #3465A4][/highlight]
Everybody have a good one. I'm working on the laser welding simulation with SYSWELD app. And met with some difficulties.
Having went through the first three steps in welding advisor, looks like step 4 has put in front of me unresolvable issue so far at least.
Step 4 requires to specify the welding process parameters like "Energy/Unit length of weld", velocity" e.t.c.
The question is that how I could specify the following parameters
1. weld line
2. Welding Group
3. Reference line
4. Start & End nodes
5. Start Element
6. And the most curious - there is an item (pop up line) that requires to pick up the heat source file (it's supposed to be an XML file)
I have been suggesting this file is generated automatically after the process type had been specified, but I have mistaken. The stuff is that until you picked up this file, the system won't allow you to go to the next step. May be somebody knows it can be solved?
Picking up the tabs listed above I can see the list of my components to be welded and nothing else.
