  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Welding stainless steel to carbon steel 8
apetr26542
108
0
0
I apologize if this is a redundant post, but I need to specify the proper electrode for welding a 3/4" diameter stainless steel rod (304) to a schedule 40 steel pipe. This will be done in the field and is part of a life line attachment.
Usually the filler metal used for weld SS to CS would not work well with whipping. whipping is a technique used with certain fast freeze steel electrodes.
Whipping can be done with SS electrodes but the arc is just NOTHING like an E6010 or 6011.
Depending on the application, the mixture may not be a problem.
Gerald Austin
Iuka, Mississippi
JLGIII
I think I understand (at least in principal) what you were trying to accomplish, but, relying on whipping to avoid zinc contamination sounds like a dangerous practice.
