kjoiner
- Oct 31, 2002
- 462
I have an application where I need to weld a hardened shaft to a mild steel plate (10 ga CRS). The plate will attach to an extruded tube. The shaft supports the plate and tube but the hardened surface is necessary for use with a drawn cup roller bearing (i.e. one way clutch bearing - needs RC 58). The shaft is nitride coated and I have checked to confirm that it is surface hardened (Rc 60) and not through hardened. My main concern is cracking after welding. Does anyone have concerns with TIG welding the shaft to the plate? Cost and time pressures are one reason I am looking at using pre-hardened shafting.
Also, are the preparation steps needed before welding such as removing the surface coating?
Thanks,
Kyle
Thanks,
Kyle
