Weldment Error
VELCROW
92
I am new to weldments, and I made a simple frame. Everything looks good, but when I go to modify the structural member feature, a little tool-tip-like window appears near the cursor, saying "Failed to trim weld members or apply a gap because of geometric conditions". After a few seconds it just goes away.
I did not do any explicit trim operations, just the built-in corner treatments. No gaps either. No other errors in the Feature Tree. Just one 3D sketch and one structural member feature(26 members).
Is this just a benign bug, or do I have a real problem?
Thanks,
Steve
How are you trying to modify the member?
What version of SW?
Can you post the weldment or at least images of it?
I don't know what the problem is, but it appears to be caused by the Group6 members. Once they are deleted, the error message is not given.
I deleted Group6, then recreated it as Group10 using the same 3D sketch elements. The squares came out rotated, so I rotated them back 45 degrees. The error came up, and I narrowed it down to one member. See attachment.
If I play with the corner treatment trim order (make both gussets a 2) I can make the artifact go away, and the error goes away.
Of course, I played the same trick on the original model, got rid of the artifact, but still had the error. Another deep mystery of modeling software.
Thanks,
Steve
 http://files.engineering.com/getfile.aspx?folder=7a6dc9c3-09d1-4c5b-a104-2ef7551e6e65&file=pipettor_frame.JPG
