domaso
Computer
- Feb 9, 2013
- 13
Sorry if this is an easy question, but I'm not really a good mechanic, so I thought some smart guys here could help me
I did a compression test on old Volvo (1998, 2.0, petrol, non-turbo). I did both "Dry" and "Wet" tests (by "Wet" I mean adding a spoonful of oil into the cylinder before measuring).
So, here are the results (cylinders 1-2-3-4):
DRY : 170psi – 170psi – 170psi – 170psi
WET: 170psi – 170psi – 245psi – 170psi
I would understand if cylinder-3 would show low compression on dry, and 170psi on wet test - it would indicate worn rings. But now dry test kinda shows All-OK on all cylinders, but it's way to high on wet test. By the way, manual says the normal pressure is 189-218psi. Yes, 170psi is quite low, but the engine has 190,000 miles on it so I guess it should be expected. On the other hand the manual says 218psi should be the highest pressure on good condition engine, while I get 245psi on an old engine.
I'm a bit baffled here... Anyone has an idea what could be the problem in cylinder-3?
P.S. I did the wet test twice on cylinder-3, and it showed 245, so I'm pretty sure it's not the gauge.
