whats up with lines that cant be trimmed or extended?
uGlay
389
when sketching sometimes ill run across a line that cant be modified. happens usually when the line is obtained via convert entities command. I know its probably something really simple and I run into this kinda thing every once in a while so i thought id ask this time.
thanks in advance.
One other note:
If you ae using the "convert entities" command on multiple edges on once, common endpoints will be constrained to each other.
Remember...
[navy]"If you don't use your head,[/navy] [idea]
[navy]your going to have to use your feet."[/navy]
