So I have been with this problem for more than a week now.
There is a big issue with Abaqus (I know this is a big allegation to be made by a learning user)
See the attached first (2 Figures), please
You can see that there is an element that one of his nodes are separated from the adjacent element!! How could this happen with no error!!
There crack length (a) starting from edge of central hole. The crack did not open along the dotted line (photo 2 in the file). Only the small part of the seam crack length its open as you can see. Why would this happen. The seam crack assigned correctly to the all the embedded face along the crack length.
The seam crack assign 2 nodes to separate crack faces. As it does not work in the current case I have,is there another way to separate the crack faces (gap between nodes of 2 attached elements)
The model is an assembly of the crack, partitions around the crack tips and the hole plates (as in photo 1). the merged (Geometry, retain boundary)
Do you have any idea what happening here, please comment if so
