WHB Thermal Design
DAO78
IT
Dear All,
Could you please advise if we could use HTRI to design SRU Waste Heat Boiler (WHB) using HTRI? If yes, please advise how to do it. Thx
you're new on this forum so we'll cut a bit of slack, but posting the same one line question on 5 forums is not allowed. Expect most to be removed.
I hope others know what your abbreviations mean, but next time use the full words and not abbreviations and add as much detail as you can about your particular query
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
The word "design" has me nervous, especially when I saw the other forums where you posted your question. HTRI, a heat exchanger design software, is not really intended to do detail AMSE boiler calculations. Please get someone with more experience in boiler design involved.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529.
Dear EnergyMix,
Thank you for your response. I am asking for thermal design not mechanical. I agree with you, we could use ASME for mechanical parts. Any clue about thermal design? Thx
I just realized that "SRU" is for a sulphur recovery unit. I really don't think that HTRI is designed for that, but you'd need to talk with someone at HTRI itself ( to find out as I don't own the program. There were a number of technical papers that came up when I googled SRU heat exchanger design; however, I'm not sure it's something that I'd want to get into -- I think it would be far cheaper to buy that than to design my own.
Thx EnergyMix for your devices. HTRI could be used with caution!!! This is based on experience. Any other feedback will be appreciated. Thx
Any SRU WHB design engineer. He could help..
You should read forum policies which begin as follows:
>>>>>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.
DAO78,
You can use HTRI to design SRU (Sulfur Recovery Unit) WHB. However, as you mentioned, you must use it with caution. Typically with SRU WHB there are other parameters, such as the velocity range of the sulfur gas which must be considered. Most of the design criteria considered in SRU WHB are proprietary to the SRU licensors as are most SRU equipment (condensers, reheaters, reflux condensers). If you've been commissioned to design a SRU WHB and have never done one before, I would recommend consulting with an engineer/company that has experience in these type of exchangers. They are very complex and can be problematic if designed incorrectly.
