Well, it isn't all that simple even if you stick to one system.
Just when you think degrees centigrade is a nice useful scale and easily converted to degrees Kelvin and more convenient than Fahrenheit and Rankin, for some reason the name changes to Celcius.
OK, fine, so its all now Celcius and Kelvin except it isn't.
I'm just going over my spreadsheet for density calculations and I now have to try and fathom out the significance of the various changes in temperature scales over the last 100 years.
The most recent change, so far as I can see, is from ITS 68 to ITS 90.
The differences between t
O68 and t
O90 are, apparently, either significant or not significant depending on what you are doing at the time. I'm now trying to fathom out if T
O68 is any different to T
O90 and I hope this site (
is going to help me rather than confuse me.
Is that the end of it? I doubt it.
Once you have committees deciding to standardise something you can be sure that when the committee meets again in 2,5 or 10 years they'll have thought of something new to do even if it is simply change the name from Centigrade to Celcius, to replace Curies with Roentgens or whatever, to redefine the standard or something else altogether. I guess it might make sense to you and me to have one big meeting and get all the changes done at once and then shoot them all so they can't come back in five years with more changes, but I guess that ain't gonna happen.
Of course, we can hardly expect any committee to meet and say "Yep, we got it right the last time" because they'd all have nothing more to do and hence an end to that particular "nice little earner"; most committees are thus, by some immutable law, eternal.
I say most, and perhaps that ought to read "all, because until I started messing with the density calculations it would never have occurred to me to think that 23
OC measured in 1926 would by the end of 1927 be some very slightly different temperature or that come 1948, 1968 and 1990 it would have changed again and again.
Of course, this gives me something else to worry about: I now wonder if Michael Mann is correcting all his temperature data to the ITS 90 scale and if his source materials are all in, or converted to, the same temperature scale? Do you think I should ask him, or is he having enough troubles with trying to get the hockey stick graph back on the map?
Is nothing sacrosanct?
JMW
