Is an Induction motor considered to be operating at Service Factor 1.0 if it is operating at rated kW output but at 90% rated voltage with 111% of the rated full-load current?
In page 2 in the second paragraph from the link, the author discusses this, but I am not clear as to what the author says with respect to the SF, especially when he mentions, 'If you have a SF of 1.15 for instance, but are operating at rated load, a voltage lower than rated load will not have much negative impact on the performance'. Is he referring to 'rated load' as rate kW output or rated Full load amps?
