gerkin6000
Materials
- Jan 28, 2010
- 2
Hi all!
Would anyone be able to help advise me about metals that react to sulphur please, or any ingredient used to make rubber?
I'm a jewellery designer using recycled rubber, and have found that the metals I'm using sometimes discolour relativley quickly when in contact with the rubber.
The rubber is bike inner tubes and I suspect its the sulphur in the butyl
rubber which is causing the discolouration.
I've been using silver plated metals and 'gilt' (which i guess is anything thats gold coloured?).
What I've found out so far is that gold should be ok to use. I'm wondering about gold fill, will sulphur react to the % that isn't gold?
I'm looking for silver and gold coloured alternatives. I'm thinking
stainless steel might be a good option? And am also wondering about
rhodium, palladium and platinum? I'm not sure what is more readily available in the form of jewellery chain and findings?
I'd be very grateful for any advice you may be able to offer.
Many thanks in advance.
