Whines about changes after v12 - or why I hate millennials... 1
Franklin M.
Aerospace
Jan 20, 2018
59
first of what looks like an ever growing list.
where did boundary drive method go in fixed axis contouring? v1899
Franklin
UG 10,13 & 18
NX 1,2,4,6,11,12 & 1899
NCL502 (yep I love Sequential Mill)
But millennials know better than you, just ask them, they'll tell you.
Jerry J.
UGV5-NX1961
Hello Franklin,
I don't know if you've found your answer yet or not, but there is a way to get it back. On a side note, every once in a while they make sweeping changes that leave some of us baffled. This is one of them. Another example is how I'm still fixing legacy engage/retract moves from when they changed how normal to part worked. Anyways, I've attached what should get it working for you again.
 https://files.engineering.com/getfile.aspx?folder=87fa1db9-dc1d-4e81-8ce1-0e74d6713a14&file=UD_Boundary_Enable.pdf
Hi Dawson70, My fix was littering my desktop with template parts from version 12. I just downloaded your pdf, I like it much better, thank you.
Franklin
UG 10,13 & 18
Hello Franklin,
That's similar to what I had to do before they fixed it (put it back). I'm glad that I was able to help.
Dawson 70, they seem to have removed the engage - retract options from the non-cutting menu also(fixed axis contour), would you happen to have a fix for that also?
After some searching and general wondering about I found the answer. Siemens added "override with smooth connections" some where along the line, if you uncheck this box in the non-cutting-moves the engage/retract options are again available. this has to be millennial driven change :)
Franklin
UG 10,13 & 18
