FiveVolts
Materials
- Aug 2, 2005
- 2
I have a small dual voltage 120/230 single phase motor that I'm trying to run on 50hz but it gets hot. If I run it at 220 or 230 60hz everything is ok. If i run it at 220 or 230 50hz it slowly increases temp. I let it get to 200 degrees before I decided it wasn't going to stop increasing temp.
My power source is an "International Power Source" Model #1251 pc. Distributed by Panel Components Corp, Iowa.
The output of my power source is verified.
Whats going on?
I'm preparing this little gizmo for shipment to Spain where they use 230v/50hz.
thanks
Whats going on?
thanks
