Dear everyone,
I want to consult you guys on this. I asked a package vendor (for a chemical injection package) to provide me both Differential Pressure and NPSH for the metering pump. However, the vendor says this is not required because the suction is flooded. See below:
For the differential pressure, vendor says this simply can not be determined because the suction is flooded (sourced tank will be atmospheric). If this is the case, shouldn't the suction pressure be 0 psig? given the discharge pressure - the differential pressure can now be determined. Correct me if I'm wrong.
For NPSH, again this will not be required because as the vendor says the suction is flooded and as long as the sourced tank and pump are mounted on the same level, NPSH is not required. I am puzzled why the vendor can not provide me the value of NPSH. Can you guys enlighten me first?
Virata
Virata
