You can also try to find the NW USA & SW Canada area. It was in the middle of a number of (shallow) plates as well, most of which later surface water wound up draining into the GOM, but obviously a lot got trapped in the sedimentry shales left over when the area lifted and dried up. North central Russia, again large continental sized drainage area pinched between some plates. West Africa, no plates, but still the sump of a continental sized drainage area. Brazil offshore, much the same drainage from former Amazon river basins. Venezuela, same, but from the northern South American drainage area east of the Andes, today's Orinoco. The eastern Mideast, maybe the general sump from the area drained by both the Tigres and the Nile / Rift valleys.
Don't get me started with the geologists. "Geologist" the closest thing any scientist is allowed to get to being called an optimist.... or a witch doctor. I can't tell you how many times I had to see a predicted 100 MMSCFD for the next 5 years turn into 25 MMSCFD for the next 30 days, then 25,000 SCFD thereafter. But with those kind of prognostications, they sure are popular around the first of the year.
Let your acquaintances be many, but your advisors one in a thousand’ ... Book of Ecclesiasticus
