WillisWashington
- Nov 12, 2002
- 2
we have a building with a bad humidity problem.
the building is in a neg. pres. in baton rouge, LA
the RH is near 80% through out the building
when I place the probe of the RH meter in the SA duct when the AC is off it reads the same as the conditioned space
when I turn on the AC the RH rises to 90% in the SA duct
why does the SA duct read higher RH than the RA
if in fact the chiller water coil is removing moisture
