Wide Flange Call Out from 1940's
chamokinawan
43
I'm looking at plans from a bridge built in the 40's and the way they called out their wide flanges is: 1- 14" x 8" WF @ 48#. I'm assuming the tick marks are correct as it is hand drafted and scanned making it not entirely readable. How would I compare that to today's nomenclature?
Most likely quantity = 1 for a WF 14 x 48 lbs per foot member.
Verify the flange you read from today's tables for a WF14 at 48 lbs/ft is actually "close to" 8 inches across.
Don't expect the actual inches (the decimal places) for web height nor flange width to be exact.
Not that anyone really needs to vouch further when SRE has weighed in, but I concur.
Thanks, everyone. I figured that's what it meant, and that the 8" was just a rough flange width. It was because some had: 1-14"x8" WF @ 48#, 2-15" C @33.9#. But i looked at a cross section and it was a wide flange sandwiched between two channels. Thanks, again for the reassurance.
