RSnow
Industrial
- Sep 20, 2009
- 5
Hi All,
Right now I am in the process of designing a wide belt sander and I have an idea that I would like to get some opinions on.
For starters I plan on using three air cylinders for the upper idler drum.
One in the middle that will push the drum upwards with stops on both ends. This will take up most of the slack in the belt and will not move once it is fully engaged. The remaining belt tension will be handled by the other two cylinders, one on each end of the shaft. Tracking can be adjusted by increasing air pressure on one side or the other.
In theory “I think” it should work but in the real world it may not as control valveing may not be adequate.
I would like to get some opinions.
