dkrpink
- Jan 11, 2007
- 16
Per the attached sketch and using basic statics you obtain different answers for the moment about A for an open structure.
The sketch shows an open structure analyzed using ASCE 7-05.
The method on the left uses a distributed load and then transfers the moment.
The method on the right breaks up the load into components and then analyzes the structure.
Both seem to meet basic static requirements but which is correct?
I lean toward the uniform load and then transfer the moment because ASCE 7-05 applies the load as a uniform load not as a force on projected vertical and horizontal surfaces.
