RHTPE
- Jun 11, 2008
- 702
I need to call on the collective wisdom of this group regarding a building undergoing renovation.
I have been asked by a contractor to evaluate a partially demolished structure for stability. What is to remain are all of the steel pipe columns, the original roof (essentially flat, 3" thick wood decking) + a subsequently installed gable roof, 12/5 pitch, wood trusses, 4 bearing points at each truss line with plywood sheathing AND a masonry gable end wall with a double door opening AT ONE END ONLY. There are steel beams supporting the wood decking running perpendicular to the ridge, and none running parallel. There are no shear walls of any sort. The columns bear on piers or foundation wall pilasters 14" below the ground level slab. The ground level slab (about 3" thick) is supported by bar joists over a crawl space. This slab was cast against and in full contact with all of the steel pipe columns supporting the roof. The plan dimensions are 63' X 113'. The ridge is 113' long. Building height is 27' at the ridge, 14' at the eaves.
For wind perpendicular to the ridge, I would analyze the wind forces as an open pitched roof (ASCE 7-10 Figure 27.4-5).
For wind parallel with the ridge I have a quandary due to the gable end wall at only one end of the structure. This is obviously not a closed building. Wind blowing against the building from the open gable end will spill around the other closed end and will generate outward force from inside and a suction force on the outside. Wind blowing against this gable end will generate forces towards the interior as well as some degree of suction on the inside face of the gable end wall. I am not totally convinced that examining it as an enclosed building in this case is completely correct.
I am modeling the columns as fixed cantilevers from the plane of the floor slab and not as pinned, simply because the floor slab was cast against an around the pipe columns. This seems to be giving the EoR some heartburn. I feel it's a valid approach. By modeling it this way I find the structure to be stable and see no need for supplemental lateral bracing, at least in the direction perpendicular to the ridge.
Perhaps you all could chime in with some advice & opinions. Please, let's not get into a debate of the merits of this method of remodeling - it is what it is and there's no changing it at this point in time.
My questions:
How would you analyze the wind forces parallel with the ridge?
Do you agree that assume the bases of the columns as fixed is valid?
Ralph
Structures Consulting
Northeast USA
My questions:
Ralph
Northeast USA
