ThorenO2
- May 24, 2019
- 51
Hello, I am working on a restaurant with a flat roof (1/4" per ft.) that slopes front to back. At the front/rear, the parapet is currently detailed in a platform manner with a continuous sill plate, vert studs, and kickers @ 32" o.c. My question is for the side walls parallel to the sloped trusses. Is it too difficult to have the contractor slope the top plate to align with the trusses and extend the roof sheathing over top, where you can install the parapet in the same manner as the front? It seems that a ledger setup would be good here with balloon framing, but it'll require some detailing (LVLs, SDS screws, clips, blocking, etc.) This may be end up being more complex to install than the sloped (2) 2x6s - save for at the side walls they'd have to stagger the cuts again for the parapet studs. So pros and cons. Were the parapet to cantilever a reasonable height, balloon framing and the ledger would work best, except that in this case the parapet studs still need kickers, which adds merit to the platform construction matching the front. I appreciate any input on detailing this. Thanks,
